I have a pipe network in my design model file which is data-referenced into my sheet file. In the model file, I have several profiles and everything works fine, but in the sheet file there is one pipe and one structure that will not show up in the profile view. The rest of the network displays correctly and the profile view is setup the same in the model file and the sheet file (same alignment, surface profiles, etc). Both parts are checked as shown on the Pipe Networks tab of the Profile View properties panel, but will not display. I have tried changing styles, deleting the problem parts and recreating them, etc with no change. Any idea what could be causing this?
~g
g
There is a known issue with 2011 (I don't see what version you are using) with profile data in viewports when there are other viewports at a different scale.
I attached a document that I submitted to Autodesk explaining the issue (support request 1-10388489041)
If this is what you are running into, I suggest creating a support request if you are on subscription.
-Bruce
Thanks, but I don't beleive that's it. For starters I'm currently running 2010, and the issue is not limited to viewports; it happens in model space as well. I will try playing with scales just to see if anything happens.
~g
