Civil 3D Forum
Drawing looks different in lay out space,
9 REPLIES 9
Message 1 of 10
JamaL9722060
695 Views, 9 Replies
I’m wondering how the same drawing looks different in the lay out space! Please, have a look on the screenshot below to find out that the same drawings looks different in the lay out mode
What might be the issue here
Thank you
Best
Jamal
Jamal Numan
9 REPLIES 9
Message 2 of 10
neilyj666
in reply to: JamaL9722060
Have you done a REGENALL?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 10
JamaL9722060
in reply to: neilyj666
Thank neilyj,
Sure! But that didn’t solve the problem (the dwg file is attached)!
Best
Jamal
Jamal Numan
Message 4 of 10
wendyloui
It looks like the layers for those labels are frozen in that viewport.
Wendy Miller Redd
Message 5 of 10
JamaL9722060
in reply to: wendyloui
Thanks Wendy,
At all, their layer is not frozen!
Best
Jamal
Jamal Numan
Message 6 of 10
wendyloui
Jamal,
Today is the first day I'm using 2013 and I'm coming from 2010 so forgive me if I'm wrong. I downloaded your drawing and looked at it.  This behavior appears to be something that I've hoped for.  That is: the labels appear different at different location in different viewports.  Try "reaching through" the viewport while you are in paperspace and dragging those labels to the desired location. When I did that and then went back to model space the dragged location was in a different place than where it was in my paperspace viewport.  This, to me is the preferred behavior.  This is behavior more like "AutoCAD" annotative objects where the objects stay at different dragged locations at different drawing scales.
Wendy Miller Redd
Message 7 of 10
JamaL9722060
Thank you Wendy for the elaboration,
  • Then where it is said that the modifications that we are being done at the model viewport are meant to be for that particular viewport but not on the original drawing on the model space? For example, the freeze option is designed to work for a particular viewport and will never affect the original drawing
  • Is there a way to synchronize based on the model (original drawing)
Best
Jamal
Jamal Numan
Message 8 of 10
wendyloui
Jamal,
I'm not sure.  This is new behavior to me so I just don't know the ins and outs of it yet.  If I find out more about it I'll let you know.
Wendy
Message 9 of 10
Jeff_M
This is the first mention I've seen of this. If this is a new attempt at getting Annotative scales working with C3D labels, it's not quite working correctly. So I would suggest that you make sure to make all of the label adjustments while in the Layout tab, through the viewport. I also highly recommend that you lock the Viewports once you have the scale set. It makes it much easier to zoom/pan when working in the viewport.
Message 10 of 10
JamaL9722060
in reply to: Jeff_M
Many thanks wendy and Jeff for the feedback. This is helpful
Best
Jamal
Jamal Numan
Rail Community
