I have created some blocks and put them on layer 0 and set them up in Point Styles and description keys.When they are inserted into the dwg. attached to a point, I can not draw a line from the center or insertion point. But I can draw a line using the POINT NUmber. Any ideas?
Thxs.
David
Why doesn't it find the insertion point/center of the symbol? Do they lose these properties as nodes?
Thxs.
David
Yes, when using a block within a point style, all AutoCAD properties such as center, quadrant, nearest, etc are lost because they are not important to a point. A point is an X Y and Z location, thus the other geometric properties of a "symbol" are irrelevant to a point location.
HTH
Zoom your CAD file into one of your blocks that the NODE osnap does not work on and post the DWG. I can take a look at it.
David
Wow - I am stumped.There is something definitely wrong with your MON point style. And I am also seeing some bad things in your CAD file. I inserted this DWG into one of my DWT's and all the same things return.
Perhaps exporting your points and bringing them back into a new DWG will help.
Sorry - perhaps you could reach out to Autodesk or your reseller for assistance. There are a few undocumented commands which might help.
