Civil 3D Forum
Drawing a Proposed Profile
5 REPLIES 5
JBR-1
408 Views, 5 Replies
I have  alignment with a EG profile, I also have a assembly for that alignment how do I sync both to make sure my assembly is following my proposed profile.
5 REPLIES 5
Jay_B
in reply to: JBR-1
In your "Corridor Properties" you'll specify the baseline (alignment),  profile (proposed profile) and your assemblies will be applied using corridor regions. Targets must be set to your existing ground surface for the Daylight subassemblies.
The sync then becomes "rebuild corridor".
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
w_davis
in reply to: JBR-1
This is the second prompt when creating a corridor that has to do with profiles on an alignment.
I have included a screenshot in a word document..
sboon
in reply to: w_davis
If you're only seeing one profile in the dropdown then that's the only profile attached to that alignment.  Check the alignment in the Toolspace and expand it to see all of the profiles.
Steve
Expert Elite Alumnus
Jay_B
in reply to: sboon
The Original Poster sent me a PM and I provided them with necessary info pertaining to creating an FG profile.
How to go about creating the FG is where they are at.
C3D 2018.1
C3D 2016 SP4
w_davis
in reply to: Jay_B
Profile Creation tools>Use tangents to draw on your current profile and then insert curves that meet your design criteria and then that proposed vertical curve will be a profile that you can choose to lay your corridor on.
Rail Community
