I have alignment with a EG profile, I also have a assembly for that alignment how do I sync both to make sure my assembly is following my proposed profile.
In your "Corridor Properties" you'll specify the baseline (alignment), profile (proposed profile) and your assemblies will be applied using corridor regions. Targets must be set to your existing ground surface for the Daylight subassemblies.
The sync then becomes "rebuild corridor".
This is the second prompt when creating a corridor that has to do with profiles on an alignment.
I have included a screenshot in a word document..
If you're only seeing one profile in the dropdown then that's the only profile attached to that alignment. Check the alignment in the Toolspace and expand it to see all of the profiles.
The Original Poster sent me a PM and I provided them with necessary info pertaining to creating an FG profile.
How to go about creating the FG is where they are at.
Profile Creation tools>Use tangents to draw on your current profile and then insert curves that meet your design criteria and then that proposed vertical curve will be a profile that you can choose to lay your corridor on.
