Active Member
shahjamil
Message 1 of 10 (4,515 Views)
Drawing Road Cross Section
4515 Views, 9 Replies
04-30-2011 11:27 AM
Hello All,
I have cross section data of the existing ground in the form of offset elevation. Can i draw cross sections from the this data? I am using Autocad Civil 3D.
Formate of the data for one section is:
Station 12+000
offset               Elevation
-25                    350
-20                    347
-15                    348
-10                    346
-5                      350
0                       351
5                       353
-25                    349
Valued Mentor
ericcollins6932
Message 2 of 10 (4,504 Views)
Re: Drawing Road Cross Section
04-30-2011 03:55 PM in reply to: shahjamil
Sure, as long as you have the alignment and direction of same to relate the offset information.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
Active Member
shahjamil
Message 3 of 10 (4,468 Views)
05-02-2011 02:17 AM in reply to: shahjamil
Can you please elaborate! What will be the precedure? Thanks in advance.
Employee
peterfunkautodesk
Message 4 of 10 (4,457 Views)
05-02-2011 05:56 AM in reply to: shahjamil
There is a command in Civil 3D under Points -> Alignments -> Import From File that will read a file formated as:
Station, Offset, Elevation
or
Station Offset Elevation
When you use the command it will prompt for a file and an alignment and bring in the points relative to that alignment. There is more information about the command and the file format in the help file.
Cheers,
Peter Funk
Peter Funk
Active Member
shahjamil
Message 5 of 10 (4,423 Views)
05-03-2011 06:12 AM in reply to: peterfunkautodesk
Thanks Mr. Peter Funk, I am a novice in Civil 3d, I have imported the points in the drawing by the procedure you described but I am stuck up now to convert these points to sample line and then draw the cross section. I explored different methods of drawing the sample lines but I am unable to find the solution. Can you please guide me in drawing the cross sections after importing the points in the drawing?
Thanks again.
Jamil
Valued Mentor
ericcollins6932
Message 6 of 10 (4,420 Views)
05-03-2011 06:19 AM in reply to: shahjamil
(borrowed from Mastering AutoCAD Civil 3D 2011, Chapter 13) (Wedding & McEachron)
Before you create sample lines, you often start with a corridor... allowing you to display materials being used, as well as to show the new surface with cut and fill areas.
I highly recommend this book for us novices...
I did take the Civil 3D essentials course, but find this book fills in a lot of the blanks. Especially if you have never taken the C3D Essentials course, I would at the very least, invest in this book. I got it online from Chapters. It runs about $70 US or $84 CDN.
16 GB RAM
Civil 3D 2012 SP2
Employee
peterfunkautodesk
Message 7 of 10 (4,404 Views)
05-03-2011 08:10 AM in reply to: shahjamil
After you import the points I would create a surface from them. Then add the surface to what the sample lines and create/update your cross sections.
Cheers,
Peter Funk
Peter Funk
Active Member
shahjamil
Message 8 of 10 (4,374 Views)
05-04-2011 04:55 AM in reply to: shahjamil
Thanks Mr. Peter Funk followed your instructions and it worked.
Member
saraswat89
Message 9 of 10 (4,355 Views)
05-04-2011 10:31 AM in reply to: shahjamil
U can do
first u draw a line and make the alignment after that you import the point from file in text csv formet  and any other quary u can contact at my cell +919001998845 and email;saraswat89@rediffmail.com
saraswat
New Member
mohan.bora
Message 10 of 10 (666 Views)
12-04-2013 07:58 AM in reply to: shahjamil
Pl.send me the tutorials with procedure to draw road cross sections for earth work
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
