AutoCAD Civil 3D General
Member
Message 1 of 7 (451 Views)
Drawing 3d Polylines from points not working...
451 Views, 6 Replies
07-01-2013 03:43 PM
I have points in a 2012 C3D drawing and I am looking to draw 3d polylines from point to point.  Ultimately I am wanting to generate breaklines for a surface from a topo.  I was able to do this a few months ago and now no matter what I try nothing seems to work.  When use the 3P command the Z Vertex is 0.  All of the points in the drawing have elevations. I tried drawing a feature line however, the beginning elevation is saying 0.  Its as if these lines do not recognize my points as having elevations.  If anyone has a solution it would be greatly appreciated...
Distinguished Contributor
Message 2 of 7 (438 Views)
Re: Drawing 3d Polylines from points not working...
07-01-2013 05:57 PM in reply to: PLS22395
Check your OSNAPZ value.
0 = Osnap uses the Z-value of the specified point
1 = Osnap substitutes the Z-value of the specified point with the elevation (ELEV) set for the current UCS
Message 3 of 7 (426 Views)
07-01-2013 08:45 PM in reply to: PLS22395
Have you checked the point style that is applied to those points to see if the Z is being flattened?
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Member
Message 4 of 7 (394 Views)
07-02-2013 07:13 AM in reply to: mathewk
Thats exactly what it was, Thank you!
Message 5 of 7 (301 Views)
08-14-2013 01:17 PM in reply to: mathewk
Mark where do you check that? I cannot find the z setting. is it in commands under point style settings????
Member
Message 6 of 7 (288 Views)
08-15-2013 07:24 AM in reply to: elaine3051
Yes it is, click on any point, right click go to point group settings, pull the tab down right of the style, click edit current, go to the 3d geometry then you can select to flatten points to an elevation or use the point elevation.
Message 7 of 7 (277 Views)
08-15-2013 02:03 PM in reply to: elaine3051
In other words, not commands, but the point style itself.
Credit where credit is due! Give kudos or accept as solution whenever you can.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
