My grips are on but the problem still exists. However, if I regenall, the
grips start appearing again. Could I have a graphics card issue?
Thanks Bill,
Sandy
"wfb" wrote in message
news:5399822@discussion.autodesk.com...
Sandy:
I suppose you are talking about "grips". Check HELP for several
combinations with grips.
Notably, Grips=0 (Off) Grips=1 (On).
Bill
"swatfor" wrote in message
news:5399759@discussion.autodesk.com...
Since installing sp3, the label location and anchor dots do not appear when
any existing or created label is selected. One exception - if the label has
already been dragged the label location and anchor dots appear.
To get the label location and anchor dots to appear, I have to do something
to the label (like a standard move command), then the dots appear but of
course moving causes the anchor to be in the wrong location. I can then do
an undo and select the label and the dots appear. This may not seem like a
big deal, but when you need to drag many many labels it really cuts back on
production.
ALL label are responding this way. Old drawing, new drawing, alignment
label, profile label, section label, old label and new label... Why aren't
the editing dots appearing when I first select the label in the first place?
Is there a fix? Is anyone else having this problem? Should I do a clean
uninstall and reinstall?
Sandy
Sandy W
Autodesk Civil 3D 2007, sp3
Windows XP Pro, sp2
Pentium 4, 3.2 Ghz
2 Gb RAM
