Civil 3D Forum
Dragged State Label Style issue of line between text not flipping
9 REPLIES 9
Message 1 of 10
4896 Views, 9 Replies
I'm having trouble getting my label style to flip when in dragged state.  If I drag it off to the right, the text and line show up just fine, but if I drag to the left, the TC and FS head that way, but the line in between stays put.  Any help would be appreciated.  Please see picture attached.  Thanks so much!
I've added some screen shots showing my settings as well.  Thanks!
9 REPLIES 9
Message 2 of 10
rl_jackson
Flip anchors (maybe?) would need style settings to be sure.
Rick Jackson
Survey CAD Technician VI
Message 3 of 10
I have the text style settings attached to my initial post, but here is the line style setting within the composer...
Message 4 of 10
wfberry
Change your display in Dragged State to "Stacked text".
Bill
Message 5 of 10
in reply to: wfberry
Thanks Bill, but when I switch to Stacked Text, it yields the result in the picture attached.  Is there a way to get the line to go all the way in between the text (extend out)?
Message 6 of 10
david.zavislan
Dragged labels using 'as composed' are not aware of the leader direction.  You will need a second style composed for dragging to the left.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 7 of 10
in reply to: david.zavislan
How would I change the leader direction in a separate style?
Message 8 of 10
david.zavislan
Edit the line component of the 'left' label style so that it goes to the left.  Change the the justification of the two text components to be left justified.
When the label is dragged the leader and leader tail will automatically change between left and right.  I highlighted this in the following image, from your original post.  The red lines indicate the leader and tail and the green lines highlight the line component from the label style.
Message 9 of 10
Thanks David!!
Message 10 of 10
denzuki1
This is not an acceptable answer. I've noticed this issue at several companies that they have two styles for all of their dragged labels; one to the left and one to the right. Why can't we have one label that will mirror itself if it is dragged to the left or to the right, regardless of the type of label it is?
Also, I can create a general note label that will flip (as composed vs stacked text) however, if I add a symbol to the label, the symbol disappears when dragged. I would like the symbol to be part of the dragged text.
Rail Community
