*Robert
Message 1 of 12 (356 Views)
Dragged Labels leaders not pointing to point ctrs.
356 Views, 11 Replies
11-09-2006 10:13 AM
I have some points labeled with elevation only. If I drag the labels away
from the point leaders are created but the arrows do not point to the
centers of the points. I looked in the label style>dragged state>leaders but
I don't see anyway to tell the leaders where to point.
*wfb
Message 2 of 12 (356 Views)
Re: Dragged Labels leaders not pointing to point ctrs.
11-09-2006 10:19 AM in reply to: *Robert
On my computer, the leaders point to the insertion point, but they do not
get very close. It was explained by Mr. Funk on an earlier post. (I.E.
several months ago.)
Bill
"Robert" wrote in message
news:5391112@discussion.autodesk.com...
*Robert
Message 3 of 12 (356 Views)
11-09-2006 10:36 AM in reply to: *Robert
Oh. Yes it's weird if I drag the label all around the point the leader will
remain outside what appears to be a force field about the size of the point
symbol, in my case an X.
"wfb" wrote in message
news:5391123@discussion.autodesk.com...
Bill
Distinguished Contributor
sduffin
Message 4 of 12 (356 Views)
03-29-2007 12:48 PM in reply to: *Robert
Has anyone come up with a solution for allowing the leader to point to the center of the marker of a point object when it is in dragged state? I am not sure that an answer was given other than referring back to Peter Funk's post -- which I can't find.
Thanks!
Member
bhammond
Message 5 of 12 (356 Views)
03-29-2007 01:25 PM in reply to: *Robert
It appears as if the leader's attachment point is to the "extents" of the point marker. If you change your point style to a "Use Custom Marker" and pick the dot, the leader arrow will be attached to the node.
MMccall
Message 6 of 12 (356 Views)
03-29-2007 01:31 PM in reply to: *Robert
I wonder if you could use a different arrow head, like something user defined, that had it's insertion point at maybe it's mid-point, instead of the tip. That way it would project ahead of the end of the leader line.
sduffin
Message 7 of 12 (356 Views)
03-29-2007 03:19 PM in reply to: *Robert
Thanks!
New Member
noryb96
Message 8 of 12 (356 Views)
11-24-2008 02:19 PM in reply to: *Robert
Perhaps this has already been addressed, but here's the solution in Civil 3D 2009. In the Point Style editor, click on the Summary tab, expand the Marker heading, and change the Leader stops at marker setting to No.
Presto!
stevenh0616
Message 9 of 12 (163 Views)
11-14-2013 11:57 AM in reply to: *Robert
Had a collegue of mine help me figure this out... I was having the same issue.
The leader connection to the point is not set in the style. It's per point. Select a point, go to properties, Under Annotation heading, Leader Attachment Option, Select Point - instead of Marker Extents or From Marker Style.
This will force the leader to the point coordinate. To do a mass selection of points, click a point, right click, hit select similar, then change in properties as stated above.
NOTE: I believe that the Leader Attachment Option from above called From Maker Style is confusing, because points do not use a Marker Style, which is an actual style in Civil 3D. They use a point style for their 'marker', in which to add more confusion does not have any settings for leader attachment. I believe that both Leader Attachement Options (From Marker Style and Marker Extents) use the extents of the marker object to calculate the end of the leader.
Steve
Windows 7 Enterprise 64-bit SP1
Intel Core i7 CPU X920 @ 1.73 GHz
16.00 GB RAM
Civil 3D 2013 64-bit SP1 HF3
Check out my AutoCAD, Civil 3D, and Map Apps on the Autodesk Exchange Store at: Autodesk Exchange Store or Red Transit Consultants, LLC Website
Jeff_M
Message 10 of 12 (160 Views)
11-14-2013 04:31 PM in reply to: stevenh0616
Steve, you do know you responded to a 5 year old thread? Second, as the post just prior to your points out, this setting CAN be controlled in the Point Style...no need to change each point.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
