Civil 3D Forum
Double Click Note Label Edit
13 REPLIES 13
Message 1 of 14
kauaieng
1464 Views, 13 Replies
I was just wondering if you can customize your interface so you can edit note labels (or any labels for that matter) by double clicking. I've already gone throught the cui files but I can't find anything. Am I missing something. c3d 2007
13 REPLIES 13
Message 2 of 14
BrianHailey
in reply to: kauaieng
I haven't tried it yet myself but check out this utility.
http://tinyurl.com/seoac
The tinyurl will take you to the civil community website.
Brian
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 14
kauaieng
Installed the new cui and it has lots of usefull features but no double click label edit
Message 4 of 14
kcobabe
Well I don't know about all labels, because some do not allow it, but here it is for general:
1. Open the customize user interface (CUI) dialog box
2. Go down to double click actions and right click select new
3. Add a name and description
4. Under Object name enter exactly this "aecc_general_note_label"
5. Now go to the commands window. Should be on your lower left. Click the new button
6. Enter the name, I suggest "Edit Label Text"
7. Enter a description if you wish
8. Under macro enter "^C^C_editlabeltext"
9. Drag and drop the new command onto the new double click action.
10. Double click to your hearts content.
You may have to set this up for different labels so here's how you can get the information:
(setq a (entget (car (entsel)))) <-select entitiy
!a <-see what the entity is should be (0 . "XXXXXX")
Do the previous stuff
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 5 of 14
JeffPaulsen
I came here looking for something else but saw this. I was planning on changing this today anyway. This worked great and I didn't have to figure it all out 😃 Thanks.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 6 of 14
tom_berning
Has anyone been able to get this to work in 2009? I followed the steps outlined above but the double click still brings up properties instead of the editlabeltext window.
Tom Berning
Woolpert, Inc.
Civil 3D 2020
Message 7 of 14
Sinc
Works fine for me in 2009.
-- Sinc
http://www.ejsurveying.com
http://www.quux.biz
http://www.sincpac3d.com
Sinc
Message 8 of 14
tom_berning
Sinc,
I'm stumped. I even tried going back to the civil.cui from a fresh install and it still doesn't work. If you don't mind, can you email me your cui file. Send it to tom.berning at woolpert.com.
Tom
Tom Berning
Woolpert, Inc.
Civil 3D 2020
Message 9 of 14
leave it to Sinc to figure out all the crazy intricacies of C3D. This a darn good tip.
Message 10 of 14
rkmcswain
in reply to: Sinc
Still works in 2013.
Message 11 of 14
kcobabe
in reply to: kcobabe
I love it when you forget how to do something and then remember you put something up on here so you can figure it out again.
I think Autodesk should start having the double click already written into the program by now, but that may just be me 😄
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 12 of 14
cstringer-ns
I've searched the forums for answers then found 10 year old posts with me asking or answering the same question a few times.
Message 13 of 14
C3D 2017 I was unable to get this to work.  I restarted C3D & still not working.  What's wrong here?CUI Double Click Edit Labels.PNGCUI Double Click Edit Labels-2.PNG
Message 14 of 14
klugb
in reply to: james.n.bennett
We do ours in a partial customization file so it can easily be added to any setup. Attached is our setup.
 Remove the ".txt" extension I added so I could attach the file.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Rail Community
