All,
I notice this little mark in the background sometimes, not sure what it is. Note there is an aerial in the background, i am curious about the circle with spokes.
Thank you for the reply. Do you know what it is actually marking, or does it have a use i am not aware of, or should i just shut it off?
That marker shows up when you set a CRS (e.g. thru _ADESETCRDSYS).
You can kill it, by setting the variable = 0
@dmartin wrote:Thank you for the reply. Do you know what it is actually marking, or does it have a use i am not aware of, or should i just shut it off?
This marker is used as a way of positioning your project on Earth. If you are designing widgets, you are not likely to use this feature. If you are designing highways, you will.
Tim
