Civil 3D Forum
Do not show Point Number in table
3 REPLIES 3
neilyj666
1438 Views, 3 Replies
I have a table of Wind Turbine coordinates but I don't want to show the point number - is this possible dynamically??
The only alternatives I've come up with are to use a wipeout but then the heading is off centre or to just explode and manipulate as CAD entities, neither of which are ideal
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
Jeff_M
in reply to: neilyj666
Edit the table style. To get the first column to show something other than the point #, copy/paste the contents from the second column into the first overwriting the PointNumber value, then delet the second column.
Jeff_M, also a frequent Swamper
There is a workaround... you can actually go into edit your table style and copy/paste a different column value into the first column in lieu of the point number.  Strange to have to do this to bypass, but I believe they didn't wan't you to ditch your point number:)
neilyj666
Thanks for the replies guys - that did the trick admirablySmiley Very Happy
...although you can't help feeling it would be easier to have a radio button/tick box to achieve this
Rail Community
