I have a 2013 Civil 3D file, in which I've generated a set of multiple profile views, using a proposed centerline of a new pipeline as the alignment, and the existing grade surface. The profile views are just fine. However, there is also an existing underground electric service running roughly parallel to this proposed pipeline. All I have to work with is a 3D polyline which shows the location and elevation of that electrical service line. Here's my issue: Right now the profile view(s) display on only the existing grade along the pipeline alignment, and that's fine. I would also like these profile views to display the location of the above described electrical line, but don't know how to get the profile veiw(s) to "see" it.
Ed
Solved by Jay_B. Go to Solution.
one way would be to turn the 3d polyline into a pipe network and add them to the views.
Joe Bouza
