Active Member
ragsdale496
Message 1 of 13 (1,662 Views)
Displaying surface, point, alignment, etc properties
1662 Views, 12 Replies
03-05-2009 09:04 AM
In pre-2009 versions of Civil3d, when you placed your cursor over a surface, near a point, near an alignment, etc; the surface elevation, point id & elevation, station, offset, etc would be displayed in a "pop-up" window next to the cursor. In 2009, it does not do this. Can I turn this feature on somehow, or did Autodesk eliminate this feature???????
Distinguished Contributor
dfarris75
Message 2 of 13 (1,662 Views)
Re: Displaying surface, point, alignment, etc properties
03-05-2009 09:45 AM in reply to: ragsdale496
Surface Props > Info tab > Show tool tips
ryan.hawken
Message 3 of 13 (1,592 Views)
04-20-2011 05:41 PM in reply to: ragsdale496
Despite having the tooltips on, the tootip display does not appear when hovering over a surface. Any ideas on what the problem could be? I'm using C3d 2011
Product Support
AlmasSuljevic
Message 4 of 13 (1,576 Views)
04-21-2011 12:24 PM in reply to: ryan.hawken
Hi Ryan,
If you have checked all these places (see link below)
http://www.civil3d.com/2007/03/who-killed-my-tooltips-four-usual-suspects/
then let us know if you have Raster Design loaded and do other files get the same issue.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
ryan.hawken
Message 5 of 13 (1,548 Views)
04-27-2011 09:03 PM in reply to: AlmasSuljevic
Thanks Almas
These options were all checked but when I unchecked and checked all of them again, my surface tooltips are back.
Just a glitch I guess.
Thanks again
Ryan
AlmasSuljevic wrote:
Hi Ryan,
Member
lonesa
Message 6 of 13 (1,320 Views)
09-13-2011 03:14 PM in reply to: ryan.hawken
We are running Raster Design and still have this issue in 2011.  Any fix yet?
Product Support
AlmasSuljevic
Message 7 of 13 (1,308 Views)
09-14-2011 05:35 AM in reply to: lonesa
I think you can run Civil 3D with plain Civil 3D icon (without loading Raster Design). You may also see if you can unload Raster Design CUI (CUILOAD command).
Almas Suljevic
Valued Mentor
engrtech
Message 8 of 13 (1,293 Views)
09-14-2011 12:15 PM in reply to: ragsdale496
The link that is being provided for www.civil3d.com always takes me to the main Autodesk page for Civil 3D.  Not sure what's happening, but I can't get to a website with www.civil3d.com as the URL.
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
Product Support
AlmasSuljevic
Message 9 of 13 (1,291 Views)
09-14-2011 12:18 PM in reply to: engrtech
Try "civil4d" : http://www.civil4d.com/2007/03/who-killed-my-tooltips-four-usual-suspects/ :smileyvery-happy:
Almas Suljevic
Valued Mentor
engrtech
Message 10 of 13 (1,288 Views)
09-14-2011 12:19 PM in reply to: AlmasSuljevic
@Almas:  That fixed the link. Thanks!
I have Raster Design installed, yet when I open Civil 3D (not using the Raster Design shortcut) I still get the ribbon tab for Raster Tools.  Raster Design isn't really loaded, yet the ribbon shows it and almost after every command the ribbon changes to the Raster Tools tab.  Extremely annoying considering I rarely use Raster Design and the fact that I didn't explicitly open Raster Design.
Does Raster Design change the profile and/or shortcut for Civil 3D?
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
