Is there a way for the elevation of surface to be shown in the bottom left corner along with the easting and northing as the cursor tracks over the surface? currently only the easting and northing track with the cursor the elevation remains 0.00
I just recently started using civil 3d again, for some reason i thought this was possible in the past. I might be mistaken. Thanks for the info.
Hey I know this is a very late reply but was just looking at this and having the same issue.
' ctrl + i ' will change it so that it shows the elvations of lines/objects when you hover over grips. For some reason it can change to a white text and no longer show co-ordinates and levels dynamicly. Maybe I knocked it at some point.
