This will probably sound like a real novice question: I recently added a new wide screen monitor to my system. Somehow the x/y axes are not equal in my drawin window, such that a drawn circle looks like an elipse, or a circle stretched on the x axis. I have tried changing the pixel setting on my overall windows display with no change in my autocad display. How do I keep the display from compressing or stretching? Thanks.
Solved by JeffPaulsen. Go to Solution.
Solved by wfberry. Go to Solution.
More than likely you have your resolution set improperly forthe monitor you are using. This is a windows and graphic card driver setup, not Autocad. Your previous one was probably 4:1 ratio, now you probably have something like 16:9 ratio.
As an example, my big monitors have the resolution set to 2560 x 1600.
Bill
Check the specs on the monitor. There should be a recommended resolution. Set your Windows display settings to match.
Thanks Bill.
I found that my monitor aspect ratio and display ratio wew not the same, even though I thought they were. Thanks for the tip. The max I can set is 1920 x 1080 on my NVIDIA gEfORCE 8600m. I'm using a 32" LCD TV/monitor at 1080p. It's set at 16:9.
It's a whole lot differentthan my previous 22" monitor and will require some readjustments.
Thanks again.
Well, I should follow the Jeff's advice, without any doubt.
You get the best performance from a flat monitor ONLY at its factory settings.
