Solved by jmayo-EE. Go to Solution.
Using the Feature Line Editing tools you can do this.
You may want to copy the parcel file so you can keep a 2d and a 3d version.
Select a Parcel Segment and the Ribbon will highlight green with the Parcel Segment contextual Ribbon tab. Click the Edit Elevations button if the Tools are not shown in the Ribbon. Select the Elevations from Surface command and assign elevations to the parcel segments. You should be able to project these segments to a profile or section view.
Another option. Put the parcel lines with surface elevations into a new surface and sample it for profiles or section. You will always get great results from this method. Object projection gets a bit flaky at times particularly if the object is closed and not symmetric with the baseline alignment.
John Mayo
How do you put the Parcel Segment line into a Surface?
I've selected a Parcel Segment line, and applied Existing Surface elevations to it. But, the next step of putting them into their own surface has stumped me.
Thanks.
