This has been discussed a few times in the past, most recently that I recall
around the 13th of this month in the thread "AECC_Contours Missing in 2010".
You don't say which version you are using, but I suspect 2010. If you have
access to 2009 or 2011, one way to work around this: open the original
drawing in one of them, explode the contours, wblock them out then paste
into the 2010 drawing.
"Cadkid1" wrote in message news:6399290@discussion.autodesk.com...
> I am editing a basemap drawing from an out-of-house source that had
> contour lines in it when I first started. There was to be no Civil3D
> editing per se, even though the drawing was opened and edited in it. The
> file was pretty low-tech to begin with. Because the drawing was already a
> confusing mess, I turned the contour layers off and edited what I was
> assigned to update. My problem is that the contours did not re-appear
> when I turned those layers back on.
> If I use quick select to select objects on that layer, it lists 134
> "ACAD_PROXY_ENTITY"s, but no grips or selections appear on the drawing.
> No type of property changes seem to make them visible again. Exploding
> them just seems to banish them to who-knows-where.
> I don't know how this file was originally created, but I think maybe it
> was with some old version of LDD. The funny thing is that I had been able
> to see the contour lines at first. When I open the original recieved
> file, the contours won't show up in it, either.
> Any help or Ideas on getting these entities to show up again would be
> appreciated.
