Hi, I use Civil 3D 2009.
I try to add direction arrow to link label on corridor section view.
In Label Style Composer it looks fine but on section view arrow head is disappeared. See the picture.
Any idea how to correct this?
Thanks.
Hi Mahod-
For some of the 2009 products with Raster Design installed there was an issue regarding solid filled objects (such as dimension arrowheads) not displaying correctly. This issue sounds very similar. Please have a look at this Hotfix and see if it resolves the issue you are experiencing: http://usa.autodesk.com/getdoc/id=DL11316517
Hope this helps!
Hi Seth,
It didn't help because of my Civil 3D product doesn't contain AeciGix51.dll to replace.
Moreover I've tested the case with Civil 3d 2011 with the same result. Arrow head doesn't appear.
Thanks.
Hi Mahod-
I tested this in Civil 3D 2011 on my machine, and the direction arrows would appear as expected if you cut your section views:
However if you are using the Corridor Section Editor, then the direction arrow heads will not appear. This is something that was intended to be used in the creation of section views, being that the Corridor Section Editor is a "temporary" representation of any given station of the corridor.
If you would like to voice your opinions about this functionality I would highly encourage you to follow this link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794 Your comments will go directly to the Product Management Team.
Hope this helps!
