I was recently given a new computer, went from XP Pro 32 OS to Windows 7 Pro 64 OS, and running C3D 2013. Before I was able to connect to ArcSDE 10 with no problems. Now when I try to login to make the connection, the login fails. I have attached an image of the message.
It's not the 3 famous dll's that need copying because I've done that. If anyone out there knows anything, your help would be greatly appreciated.
Daneisha W
@Anonymous wrote:I was recently given a new computer, went from XP Pro 32 OS to Windows 7 Pro 64 OS,
Daneisha W
Are the 3 dlls of the 64 bit version?
Hi Daneisha,
Yes, as Murph points out, because you changed from a 32-bit to a 64-bit operating system, you'll need to get 64-bit DLLs now. Whoever runs the ArcSDE server at your organization should be able to provide you with the files.
AAAAAHHHHH.. THE LITTLE THINGS!!!!!! I'll check into that but I'm almost sure thats what the problem is. I'll let you know next week. THANKS Murph and Phil!!!!
