I have have an aligned dimension that does not rotate in a paper space print window. Contour labels, alignment labels all rotate except for the dimension. Obviously I am missing something, but I have tried all I know. Thanks.
Joe Bouza
Thanks Joseph for your reply.
Maybe I should have included a little more info.
I did have the dimension set as annotative. I even went back to the Standard dimstyle and set that to annotative and even then it would not rotate properly in the window.
The problem with me changing the direction of how it reads is that the same dimension is in different viewports and those viewports are rotated differently (i.e. an overall and a "blow-up" of the area).
I don't want to give up yet.
Gary
Hi Gary, No worries
Annotative stuff can be finicky. Ssometimes an audit can set things right. Is the issue only in this drawing or do you see it in say a test drawing too?
Joe Bouza
Joseph,
I don't know why I tried this but when I exploded the dimension and then set the definitions for the annotation (i.e. Match Orientation to Layout) to yes it worked. Probably not the most efficient way but it works and sometimes it is not how you get there it is that you got there.
Thanks for your help.
Gary
Joe Bouza
