Civil 3D Forum
Different structure label style in same pipe network?
4 REPLIES 4
millermccoy
348 Views, 4 Replies
How do you have a different structure label style for different structures in the same pipe network?
2015 Civil 3D
4 REPLIES 4
wfberry
in reply to: millermccoy
You should have several structure labels composed under the structure label styles in Settings.
There is more than one way, here is one.
1. Open the PROPERTIES Toolbar box. (If not open, enter Properties in command line.)
2.  Select a structure label you want to change.
3.  In the Properties Toolbar, select "Structure Label Style", use down arrow to right to change.
Bill
millermccoy
in reply to: wfberry
under properties you can change the style...but there is no option to change the label style
2015 Civil 3D
Jeff_M
Select the LABEL, not the structure.
millermccoy
in reply to: Jeff_M
oh...it must be Monday
thanks!
2015 Civil 3D
Rail Community
