AutoCAD Civil 3D General
Active Member
Message 1 of 3 (330 Views)
Different alignment offsets with the same profile
330 Views, 2 Replies
01-10-2013 05:13 PM
I created a profile for an alignment (which has 2 offsets) and also an assembly with two assembly offsets.
I wanted to create a corridor where my assembly offsets will have the same profile but will be on different alignments  (alignment offsets).
In the corridor properties / parameters, I got an error : duplicate profile found.
Should I copy the profile (for each offset) in different profile views (for each offset) ? Or there is a better way to do that ?
Thank you.
Active Member
Message 2 of 3 (314 Views)
Re: Different alignment offsets with the same profile
01-10-2013 07:03 PM in reply to: dyoxyne
One more question, the alignment offset has a type : offset (logical) but I can't apply cant to it.
I changed it to : Rail but I don't think it's a good way.
Anyone knows ?
*Expert Elite*
Adriano_cad
Message 3 of 3 (290 Views)
01-11-2013 09:06 AM in reply to: dyoxyne
Hello
To use a project profile on an offset alignment, you need to create the profile of the surface for the alignment offset, and then use the command _AeccSuperimposeProfile to profile the central alignment be used in Offset.
bye
Adriano Oliveira
*Expert Elite*
MaxiCAD Informática
www.maxicad.com.br
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
