Civil 3D Forum
Different alignment offsets with the same profile
2 REPLIES 2
1096 Views, 2 Replies
I created a profile for an alignment (which has 2 offsets) and also an assembly with two assembly offsets.
I wanted to create a corridor where my assembly offsets will have the same profile but will be on different alignments  (alignment offsets).
In the corridor properties / parameters, I got an error : duplicate profile found.
Should I copy the profile (for each offset) in different profile views (for each offset) ? Or there is a better way to do that ?
Thank you.
2 REPLIES 2
One more question, the alignment offset has a type : offset (logical) but I can't apply cant to it.
I changed it to : Rail but I don't think it's a good way.
Anyone knows ?
Adriano_cad
Hello
To use a project profile on an offset alignment, you need to create the profile of the surface for the alignment offset, and then use the command _AeccSuperimposeProfile to profile the central alignment be used in Offset.
bye
Adriano Oliveira
Diretor Soluções BIM MaxiCAD
MaxiCAD Soluções e Educação BIM.
Facebook | Twitter | LinkedIn
some text
Rail Community
