OHHHHHHH - Go to your Settings toolspace and select surface-Label
Styles-contour. this is where you add/change your contour labels.I have to
major styles (Existing and Proposed). and each of those have child styles
(Major and Minor). That way I can control the look and feel of each. Is THIS
what you're after??
Rick
wrote in message news:5434323@discussion.autodesk.com...
Rick,
All I see in the information area is the "surface style" selection and the
"render material style" selection - nothing about adding a contour label
style to the surface style. I am currently using two different surface
styles and want each of them to use different contour label styles. For some
reason I cannot find an option to apply anything other than the "default"
contour label style to a surface.
Thanks.
Byron.
Rick
coauthor Mastering Civil 3D 2012
I blog at http://simplycivil3d.wordpress.com
