Civil 3D Forum
Different Elvations
12 REPLIES 12
Message 1 of 13
BrianD17
286 Views, 12 Replies
Different Elvations
Just created an existing grades (eg) surface from a survey.  When I hover near a spot elevation from the survey of 830.31 I get an eg reading of 830.011.  In other places they are the same or very close, others not.  I'm not sure which number to go with, the one from the survey or the one from the surface created from the survey.  Have i done something wrong when i set the surface up?
Thanks-
Brian
12 REPLIES 12
Message 2 of 13
troma
in reply to: BrianD17
I'm wondering exactly how "near" to the spot elevation you are.  If you are exactly on the spot, the surface should be exaclty the same. Try zooming in.  There might be a steeper slope in some areas than others; in a flat area you will get close to the same elevation as the spot even if you're off it a bit, in a steep area it will be more noticeable.
Mark Green
Working on Civil 3D in Canada
Message 3 of 13
BrianD17
in reply to: troma
Thanks for the reply and it's a fair question.  I put a spot on the eg surface and snapped it to the survey point and have attached.  It's not the same point i referenced in the original question but same issue.  I'd be happy with pretty close but a couple of inches is just too much.  The spots are the middle of the street so it should be somewhat flat.
Message 4 of 13
troma
Do you have any edits recorded in the surface properties?
Mark Green
Message 5 of 13
mathewkol
Look in surface properties, definition tab. Do you see any "transformed by" entries? This would mean that the surface was moved.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 6 of 13
BrianD17
in reply to: troma
Yes, but I'm not sure what they mean.
Message 7 of 13
troma
You've built this surface from contours, not from cogo points.
Mark Green
Message 8 of 13
mathewkol
For the top half of your image it doesn't matter. There are none in the bottom half so you're good on this front.
Matt Kolberg
Message 9 of 13
BrianD17
in reply to: troma
correct, followed one of the tutorials.  I'm not sure what cogo's are.
Message 10 of 13
mathewkol
But you're not using points, you're using contours to define your surface. Hence the difference in elevation.
Matt Kolberg
Message 11 of 13
troma
cogo points would be the spot heights from the survey that you are looking at (probably)
Where did you get the contours from?
Mark Green
Message 12 of 13
BrianD17
in reply to: troma
the contours and the spots were broken out of a survey file.
Message 13 of 13
Neilw_05
Just an FYI, in the Civil 3D world when we say a surface was built from survey, many of us take that to mean the survey module was used to create the components of the surface. It is not the same as using points, breaklines and contours from a CAD file to build a surface. So in future posts it would help to make that distinction as the solutions to a problem depends on what method was used.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Rail Community
