I would like to ask if there is a way to get an expression that calculated the difference between two points and pick up the results as point elevation.
Any advice will be appreciated.
I'd probably use a volume surface for this task
neilyj (No connection with Autodesk other than using the products in the real world)
Can you explain Mr.neilyj the procedure of it.
But is it helpfull because i have almost around 20 points
I will be appreciate for your advice
Thank you.
I think neilyj's suggestion is predicated on the fact that the points in question share a common x,y coordinate. If so divide them into two group A & B, create two surfaces A & B with the appropriate points. then create a volume surface C; this can be selected in the pop down while creating a surface. make the base surface A and the comparison surface B. The resultant surface will be the difference between A & B, you can then, if desired create another set of point C and assign elevations from surface C
Joe Bouza
@Joe-Bouza wrote:I think neilyj's suggestion is predicated on the fact that the points in question share a common x,y coordinate. If so divide them into two group A & B, create two surfaces A & B with the appropriate points. then create a volume surface C; this can be selected in the pop down while creating a surface. make the base surface A and the comparison surface B. The resultant surface will be the difference between A & B, you can then, if desired create another set of point C and assign elevations from surface C
Whilst the OP's requirements aren't clear this is not always necessary - for the final step you could create a new group made up of point group A or B (or any combination) and assign the elevations from surface C. This will give the elevation from a known point to an interpolated level on the other surface.
As Neil said, a little more info would be helpful.
You could draw a feature line between two points and use an expression to report delta z as well as the tin vol surface.
John Mayo
