Hi
Everytime I go to 'save as' the dialogue box does not show. All that it will do is ask me what file format I want and to type in the path (see pictures). Can anyone help me to rectify this.
Solved by MikeEvansUK. Go to Solution.
As a permanent fix you can change the file command macros as in the attachment for FILE OPEN, then FILEDIA will be automatically reset to its correct value every time you use a file command. In case it's not clear in the attached image, those are semicolons separating "FILEDIA" and "1" and the rest of the command.
As a permanent fix you can change the file command macros as in the attachment for FILE OPEN, then FILEDIA will be automatically reset to its correct value every time you use a file command. In case it's not clear, those are semicolons separating "FILEDIA" and "1" and the rest of the command.
