Member
enleru
Message 1 of 5 (194 Views)
Dialogue box
194 Views, 4 Replies
11-26-2013 03:35 AM
Hi
Everytime I go to 'save as' the dialogue box does not show. All that it will do is ask me what file format I want and to type in the path (see pictures). Can anyone help me to rectify this.
mikeevans
Message 2 of 5 (191 Views)
Re: Dialogue box
11-26-2013 03:38 AM in reply to: enleru
Variables are incorrect.
Filedia = 0/1
Attdia = 0/1
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Member
enleru
Message 3 of 5 (189 Views)
Re: Dialogue box
11-26-2013 03:45 AM in reply to: mikeevans
Thank you
Valued Contributor
HansSMS
Message 4 of 5 (120 Views)
Re: Dialogue box
11-27-2013 04:14 PM in reply to: enleru
As a permanent fix you can change the file command macros as in the attachment for FILE OPEN, then FILEDIA will be automatically reset to its correct value every time you use a file command.  In case it's not clear in the attached image, those are semicolons separating "FILEDIA" and "1" and the rest of the command.
Hans Moller
Surveying & Management Services
Gladstone Australia
Clevo Metabox 16GB, Intel i7-3720QM 3.1Ghz, 256GB SSD, Nvidia GTX 680M
AutoCAD Civil 3D 2013
Valued Contributor
HansSMS
Message 5 of 5 (120 Views)
Re: Dialogue box
As a permanent fix you can change the file command macros as in the attachment for FILE OPEN, then FILEDIA will be automatically reset to its correct value every time you use a file command.  In case it's not clear, those are semicolons separating "FILEDIA" and "1" and the rest of the command.
Hans Moller
Gladstone Australia
