We recently upgraded to Civil 3d 2014 and have had a strange box show up after printing to PDF. We use Acroplot to print to PDF. Please see attachment. It has only happened to 3 users so far and one user's system stopped doing it. Thank you.
Also did you experience a slow open and processing initially when you made the switch to 2014 (we upgraded from 2011 c3d). We suspect it may be a conversion of files causing this. Many of the xrefs or DS have not been saved in 2014.
Solved by Jeff_M. Go to Solution.
AND probably tomorrow, you may hear. I'll be baaack!
I know, I use AcroPLOT as well.
And also a hearty THANK YOU to Jeff as usual.
Bill
@Anonymous_carr wrote:
thank you...that solved the problem. Perhaps it is due to an old version of Acroplot.
AFAIK - it's an AutoCAD problem.
I've seen this with various print drivers, not just Acroplot.
