TRogers
Message 1 of 14 (598 Views)
Detention Pond Contours Not Correct
598 Views, 13 Replies
12-11-2012 12:38 PM
I have 2 feature lines, one is at elevation 132 (TOB), and the other at 123 (TOE).  I inserted elevation points at an increment of every 3 ft., which should make a smooth arc of contours around the pond.  Not the case.  How do I fix the issue I am having?  See pic below...
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
LisaPohlmeyer
Message 2 of 14 (589 Views)
Re: Detention Pond Contours Not Correct
12-11-2012 01:07 PM in reply to: TRogers
Is your surface set to use a maximum triangle length?
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
sboon
Message 3 of 14 (584 Views)
12-11-2012 01:15 PM in reply to: TRogers
Switch your surface style to display the TIN lines.  The rules of Delauney triangulation generally force the surface to connect surface points to their nearest neighbours, so in this case you likely have lines running across the inside of your curves, instead of from the inside to the outside featureline.
TRogers
Message 4 of 14 (579 Views)
12-11-2012 01:19 PM in reply to: sboon
*Civil 3DJ*
Todd Rogers
Visit my blog here.
jmayo
Message 5 of 14 (573 Views)
12-11-2012 01:34 PM in reply to: TRogers
The quick way to fix this is to add them to the surface definition as contours making sure to minimize the flat areas. If you add them as breaklines you will be flippin' all those edges.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
jmayo
Message 6 of 14 (572 Views)
12-11-2012 01:36 PM in reply to: jmayo
... you will have fewer triangles to flip and a better performing surface if you remove all those elev points.
John Mayo, PE
IDSP 2014
TRogers
Message 7 of 14 (568 Views)
12-11-2012 01:41 PM in reply to: jmayo
It's not allowing me to add the feature lines as contours...
*Civil 3DJ*
Todd Rogers
Visit my blog here.
jmayo
Message 8 of 14 (558 Views)
12-11-2012 01:52 PM in reply to: TRogers
Oh that's a bit of a bummer. I do use simple plines for basin & bld pad surfaces quite often. Not the greatest solution but if the basin was disconnected from the rest of the design it may not be a big deal losing the dynamic capabilities.
The other option is flipping the edges. In both cases I would remove the elv pnts.
John Mayo, PE
IDSP 2014
jmayo
Message 9 of 14 (553 Views)
12-11-2012 01:55 PM in reply to: TRogers
A grading (I don't like these) or corridor are other options but it does not look like the top and bottom outer curves have the same radius as the offset. The lack of symmetry makes these options tough.
John Mayo, PE
IDSP 2014
TRogers
Message 10 of 14 (552 Views)
12-11-2012 01:56 PM in reply to: jmayo
I did remove the elevation points.  I exploded the feature lines and added the poly's as contours.  MUCH more control this way.  I will have to remember this workaround.  Thanks for the info!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
