Civil 3D Forum
Detaching Excel Data Link
5 REPLIES 5
BWYarger
2915 Views, 5 Replies
In our template, there is an Excel table that I want to delete because it never should have been in the template in the first place, but I can't use the xref manager to delete it.  As the bottom of the xref manager it says can't detach, reload or unload.  I deleted the table from the drawing and still can't detach it.  I logged in as Tony on the same computer used to create link, and still can't deleted it.  What do I need to do to delete it?  I have attached a screen shot.
Brad
LT, C3D 2005 - 2024
Windows XP, Vista, 7, 10, 11
5 REPLIES 5
Jay_B
in reply to: BWYarger
Enter _DATALINK @ command line and Rt. Click on Datalink name in Dialog>Delete.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Because the table is attached as a data link you can't remove it from the X-Ref manager. You need bring up the data link manager by typing "data link" go to the file under links, right click and delete.
mpinkney
I have this issue too, but I can't delete the link. I get an error saying it's being used. The path is from someone's local drive that does not exist. Any suggestions. I'm using 2015 LT.
Mike
in reply to: mpinkney
Do you have a table that is referencing the data link in the drawing? If so, you have to delete the table first then you can delete the date link as stated in previous comments.
rogers9Z2PF
in reply to: Jay_B
Thank you, Jay.
-Roger
Rail Community
