Active Contributor
Jon0001
Message 1 of 5 (220 Views)
Design Surface Wavy at transtion to and from superelevation
220 Views, 4 Replies
06-27-2012 11:27 AM
wavy surface.PNGAs you can see from the attached image my surface is way through the in and out transition of my superelevation. the waves are dependent on frequency (ie if i change from 1m to 5m the waves get longer. Does anyone know what causes this and how to fix it?
wfberry
Message 2 of 5 (211 Views)
Re: Design Surface Wavy at transtion to and from superelevation
06-27-2012 01:20 PM in reply to: Jon0001
Turn on your tin lines to see the problem.
Bill
Joe-Bouza
Message 3 of 5 (207 Views)
06-27-2012 01:43 PM in reply to: Jon0001
Also, Smooth srface by polygon is good for stuff like that. But I agree with Bill, check the TIN line first you may have a blown target?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Active Contributor
Jon0001
Message 4 of 5 (199 Views)
06-27-2012 03:08 PM in reply to: Joe-Bouza
The TIN looks fine no problems there. I will try smooth surface .
wfberry
Message 5 of 5 (182 Views)
06-28-2012 05:33 AM in reply to: Jon0001
Show that same picture with the tin lines showing.
Bill
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
