> {quote:title=Guest wrote:}{quote}
> You cannot control layers using groups, but the general consensus is that
> you don't have to. Instead of turning a layer on and off you use the point
> and label styles to control visibility of them.
In our usage here, we actually use a combination.
Looking at just field data, the field points are all assigned specific layers and styles, based on the Desc Key. We also have a bunch of high-level Point Groups, such as Pavement points, Utility points, etc. For example, our Utility Point Group has all the utilities in it. However, individual points in that Point Group are on different layers - water points, electric points, sanitary points, etc.
So now we can turn of an entire class of points by overriding the styles in the Point Group, or we can turn items on and off with a finer level of control by using Layers. This setup gives us a lot of flexibility, but without all the problems that arise from having too many Point Groups.
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
