Civil 3D Forum
Description Key layer set to no values after values set?
1 REPLY 1
LeafRiders
233 Views, 1 Reply
Is there a way to have no layer value set for the description keys. I set all the layers, and now I realize I'd rather set this to no layers (boxes are all unchecked). I'd rather see no value under the layer column, but there doesn't seem like a way to set this. Anyone have a solution?
1 REPLY 1
machadt
in reply to: LeafRiders
Hi Kelly,
If you reimport the point using your description key but with the layers unchecked and overwrite the point information when reinserting them all the points will go to the default layer but using the rest of the setting under the description key set.
Tatiana Machado
AEC-ENI Application Engineer
Rail Community
