Civil 3D Forum
Description Key Sets...
5 REPLIES 5
1450 Views, 5 Replies
Is there a way to copy a Description Key Set from Civil 3d 2011 to Civil 3d 2009
5 REPLIES 5
Jeff_M
Thanks Jeff I appreciate the help and can't wait to give it a try.  My 1st attempt resulted in an error message "Application attempted to perform an operation not allowed by the security policy.  To grant this application the required permission....."  I have my IT people working on it now.  I'm sure it is a setting on my end so I'm confident we will get it figured out.  Thanks for responding.
Jeff_M
It sounds like you have it on a network drive. The DLL MUST be run from a local drive (unless special settings are done, which I have no idea about)....that's the way it is with .NET dll's.
I suspected you would know what the problem was...I was trying to run it from a network drive.  Moved it to my local drive and worked like a charm.  Our description key set is based on our state DOTD point codes so it has 900 plus keys.  Saved me days of monotony
d_prontnicki
in reply to: Jeff_M
Hi Jeff,
Any chance you have updated this for use in 2018 and 2016? I need to export Desc Key Set from 2018 and import into 2016.
Thank you!!
Rail Community
