Is there a way to change a RAW description such as EC12 +, or EC11 -, to say SWP12 +, SWP11 -
I'm not having much luck using the parameter settings. 1$
I tried Code = EC*, format=SWP1$
That didn't work... I got literally SWP1$ instead of SWP12 +
Is it a space thing? Do I have to rename all the descriptions to have a space before the parameter?
i.e. EC 12 +
I'm hoping this isn't the case and some form of wildcard can be use.
Solved by civ_engineer. Go to Solution.
Not entirely sure I'm following you... But could maybe a search/replace in Excel (or a text editor, if you're using FBK) work...? (This would need to be done prior to importing the data into C3D.)
I guess I'm mainly trying to figure out how to use the parameters 1$ 2$ etc.
within description keys. I've seen some examples used for changing the full descriptions for trees from
say.. TREE 12 PINE to 12" PINE
I figured I should be able to rename my EC points there as well.
For example, I have points like EC11 +, EC12 -, etc. I'd like to use description keys to change EC to SWP but keep the remainder.. 11 +, 12 -
Is that not possible?
I seem to be able to change the name but loose the remainder.
The $1 $2 etc. parameters use spaces as a delimiter.
So in the following key:
TREE 12 PINE
$0 = TREE
$1 = 12
$2 = PINE
$+ = 12 PINE
$* = TREE 12 PINE
That's about the only options you have. There's no way to "split up" stuff unless there's a space. So you can't use these codes to substitute part of a parameter while leaving the remainder untouched.
