Civil 3D Forum
Desciption Key w/ Field Code Escape
4 REPLIES 4
sjg
485 Views, 4 Replies
Why is that if I import some points that have a "/" (field code escape) the symbol does not come in. For Example: TP/ 1' N.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
4 REPLIES 4
sboon
in reply to: sjg
Is "TP/" in your Description Key set?
Steve
Expert Elite Alumnus
sjg
in reply to: sboon
No, what is the proper method to add a note after a description key (TP), for a survey shot, I guess the "/' (field code escape) is just for linework. I would have thought the field code escape would have worked for both.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
IanMcClain
in reply to: sjg
Use a space after the TP code. Codes recognize space as a deliminter, but they don't recognize "/", that is only for figure prefiz commands. I don't think you need a space after the "/", so either "TP /1' N" or "TP / 1' N" would work.
If you still have problems withe the description, try removing the ' as well. That could be truncating your description. I always use FT or IN in my description codes because of that.
Ian McClain
sjg
in reply to: IanMcClain
That worked, thanks.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Rail Community
