It seems that if there is a point style override for the desc key set to a
point style that uses an AutoCAD block symbol for the marker, the point
won't freeze with its layer.
Or, even if there is no override, but the group point style uses an AutoCAD
block symbol for the marker, the point won't freeze with its layer.
"Darron Agawa" wrote in message
news:A3D6BF50905C4F5BF9C1BBE9F35D87F7@in.WebX.maYIadrTaRb...
> After doing a little experimenting, here's what I've found:
> I think the problem you're running into is that for some unknown reason
C3D
> doesn't update points when freezing some layers. I could be wrong, but if
> any desckey layer is frozen, it doesn't update the points on the screen.
> But if you freeze a point group layer, it does a regen and all the points
in
> that group disappear. So basically, when you freeze your desckey layer,
try
> a regen and see if you're still having the same problem. Thawing the
layer
> does do a regen, so it seems like a bug.
> I think the logic behind putting layer settings in both point groups and
> desckeys is grouping similar points, but still keeping them seperate in
> regards to the desckeys. For example, grouping all the concrete points
> (EOC, TOC, TBC, BOW) so you can freeze all of them at once, but still
being
> able to freeze one at a time.
> Darron K. Agawa
> Civil Engineer
> Town of Windsor
