Deriving “counter clockwise” azimuth from “clockwise,
I’m wondering if there is a technique to automatically derive the counter clockwise azimuth from the clockwise or vice versa.
Thank you
Best
Jamal
Solved by troma. Go to Solution.
Solved by AllenJessup. Go to Solution.
@JamaL9722060 wrote:Deriving “counter clockwise” azimuth from “clockwise,
For Figures and Polylines the direction arrows in your caption will be pointed in the direction the shape or lines were drawn when labels are added.
Draw 2 closed polyline shapes.
1st clockwise direction.
2nd counterclockwise direction.
Label both shapes and arrows should be opposite directions.
For "Parcels" there is a command line prompt for user to specify clockwise or counterclockwise label direction when adding labels but AFAIK, there's no such option for labeling Polylines or Figures.
Simply select the label, right click and select Reverse Label.
The command line is LABELREVERSEBEARING but it works on Azimuths also.
Allen Jessup
Allen Jessup
CAD Manager - Designer
You can reverse a label once it is created by selecting the label and on the Labels context tab, click reverse label.
If you want to create labels that are the reverse angle to the line direction have a look into label expressions.
You can take the normal angle direction and turn it into a reverse angle direction and feed that to a label style.
Angle calculations in expressions are done in radians. 360 deg = 2 * pi radians.
Allen Jessup
Mark Green
Working on Civil 3D in Canada
Many thanks guys for the help, it works fine.
Best
Jamal
