I have a plan I want to create a table of feature line (the ones used as ditch cl's) with the designation (ie R1), the overall length (this part I can do) and then the Delta z of the entire featureline. I can get segment Delta z, but not the entire Delta z.
Thanks in advance for your help!
Solved by jmayo-EE. Go to Solution.
This is one of MANY label wishes that have been outstanding for years. It cannot be done OOTB with C3D labels.
John Mayo
Is there a way to pull the minimum and maximum elevations out of the featureline properties and use that in a label?
Just trying to find a work around, but will have to do it manually (still) if not
Thanks again
Just trying to list all of the Civil 3D Label wishes huh? 😉
Just kidding but unfortunatly that is more of the Civil object data that is locked up tighter than we would prefer.
If you want more of what we have been asking for search the C3D Wishlist newsgroup for 'Labels'. 300 wishes.
John Mayo
