As I was creating a surface consisted of contour lines, suddenly some bunch of random points in the surface were also created. I want my surface to be solely generated by contour lines only. So...
I know I can get rid of those points by deleting them through edit but I want to get rid of them all at once. How can I do that? Or... Is there even a way to do that?
Solved by ToddRogers-WPM. Go to Solution.
Solved by jmayo-EE. Go to Solution.
If you added the contours to the srf definition as contours objects remove them and add them again but turn off all the options that add points to minimized flat areas.
Thank you! Thank you! I totally missed this part at the beginning.
Thank you! This is a great tool. I've never used this before. Tnx 😄
