Civil 3D Forum
Delete or rename databases
7 REPLIES 7
Message 1 of 8
DawnAW
1960 Views, 7 Replies
I have figured out how to delete the survey databases but I haven't figured out how to delete or rename the Equipment, Figure Prefix, and Linework Code databases.  Does anyone know of a way?
7 REPLIES 7
Message 2 of 8
AlmasSuljevic
in reply to: DawnAW
These files are foun in here: C:\ProgramData\Autodesk\C3D 2011\enu\Survey. See if you can delete and rename them there.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 8
DawnAW
in reply to: DawnAW
hmmm...I can't find that path.  I am still working with Windows XP, maybe that explains it?
Message 4 of 8
AlmasSuljevic
in reply to: DawnAW
In Windows XP that path is C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2011\enu\Survey. Look for EDB and FDB files.
Almas Suljevic
Message 5 of 8
in reply to: DawnAW
Under Survey Tab, click the Survey User Settings (upper left hand corner), check the path for Figure Defaults and others.
Message 6 of 8
DawnAW
in reply to: AlmasSuljevic
That did it!  Thanks for all the help!!
Message 7 of 8
Fantoon
in reply to: DawnAW
Thank you, this post helped me with my issue as well!
AutoCad 2019 & Civil3D 2019.
Lenovo P52
Intel i7 8850H @ 2.6GHz
32 GB RAM
512 GB SSD
NVIDIA Quadro P2000
Message 8 of 8
Wait, really? This is the designed technique to delete an Equipment Database? The user has to actually leave Civil 3D, hunt around in the Windows file system to find the equipment database (or figure prefix library) they wish to delete and remove it manually using Windows? How about 'right-click on it in the Survey Toolspace and click Delete?' -- You know, like how we copied the database in the first place...
This seems like a very clunky work around to me. Why can we not just delete them through Civil 3D?
Rail Community
