AutoCAD Civil 3D General
tm
Member
tm
Message 1 of 10 (9,874 Views)
Delete key doesn't work, Can't edit text
9874 Views, 9 Replies
03-04-2009 04:11 PM
Any ideas? I have to go up to cut and select the object to delete. Also when I click on text the edit dialogue box doesn't come up. I have to go to properties to edit.
*Jeff Mishler
Message 2 of 10 (9,874 Views)
Re: Delete key doesn't work, Can't edit text
03-04-2009 04:21 PM in reply to: tm
Make sure the Pickfirst system variable is set to
1
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Any
properties to edit.
tm
Member
tm
Message 3 of 10 (9,874 Views)
03-04-2009 05:12 PM in reply to: tm
Thanks Jeff your awesome!
Member
stiedemann
Message 4 of 10 (9,874 Views)
04-28-2009 09:18 AM in reply to: tm
I have had the same problem a couple of times already and the only way to remedy the situation is to completely uninstall and re-install Civil3D. My Problem started with not being able to edit text, then not being able to use the delete key, and then the right click options pop-up box becomes unusable. I have re-installed Civil 3D for the third time and now my text editing by double clicking the text is not working. Can anyone help on this before I have to re-install for a forth time???
Member
stiedemann
Message 5 of 10 (9,874 Views)
tm
Member
tm
Message 6 of 10 (9,874 Views)
04-28-2009 01:29 PM in reply to: tm
Check out Jeff's reply on my post. This worked like a charm for me. I have not had the problem again.
Member
stiedemann
Message 7 of 10 (9,874 Views)
04-28-2009 01:37 PM in reply to: tm
I tried that PICKFIRST command which didn't work for the text editing but the DBLCLKEDIT command worked for that. I still can't figure out why the right click properties is not working, but i am on the hunt
New Member
amgedgoga
Message 8 of 10 (7,899 Views)
12-01-2012 03:41 AM in reply to: stiedemann
try "audit" and fix all, i think it will be usefull, i ahd same problem before
Member
peterchrien
Message 9 of 10 (7,472 Views)
01-24-2013 02:54 AM in reply to: tm
PickFirst worked for me very well :smileyhappy: thx
Member
meihum
Message 10 of 10 (6,163 Views)
05-10-2013 02:14 AM in reply to: amgedgoga
audit worked for me - cheers
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
