Show only
Search instead for
Ok... I think I am either having a severe brain fart or I just am missing something (the brain part). I am trying to create an expression so that I can put the Dc into my alignment curve label. I am using (5729.58/Radius) for the expression and using Double for the format which comes out fine in decimal form as in a curve with a 200' R comes out to be 28.6479º, the problem is that I need it to come out as Angular DMS... when I switch the format to angle it comes back as 1641º24'14". What am I missing.
Expression: ASIN(50/Radius)*2
Format result as: Angle
Make sure in the Label Style Composer you have the units and format correct. When i played with this i had the issue of the label reverting back to Decimal form, i would have to go back and specify the units again to get it to show as DMS.
Edit-I did this in '07
Message was edited by: Dustin M
