AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 5 (425 Views)
Degree of Curve Label
425 Views, 4 Replies
08-19-2009 06:59 AM
I am using 2010 Civil 3D. I would like to include in my alignment curve label the "degree of curve". Any help or a practice how to create this is appreciated.
*wfb
Message 2 of 5 (425 Views)
Re: Degree of Curve Label
08-19-2009 07:05 AM in reply to: jak79
Hopefully you know how to use the Label Style Composer. In the Text
Component Editor there are two versions, Degree of Curvature by Arc and the
Degree of Curvature by Chord.
Bill
wrote in message news:6239599@discussion.autodesk.com...
appreciated.
Message 3 of 5 (425 Views)
08-19-2009 07:20 AM in reply to: jak79
Thanks for the help Bill. I attached an image of the available properties in my Text Component Editor. I don't have the two you mentioned. Am I in the right spot or do I need to add those in some how?
*Peter Funk - Autodesk, Inc.
Message 4 of 5 (425 Views)
08-19-2009 08:14 AM in reply to: jak79
Those properties are in the Alignment Curve label and not in the General
Curve label.
Peter Funk
Message 5 of 5 (425 Views)
08-19-2009 08:23 AM in reply to: jak79
Thanks Peter that was what I needed. Thanks again for your time.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
