AutoCAD Civil 3D General
yasin2ray
Message 1 of 12 (3,205 Views)
Defpoints layer not selectable
3205 Views, 11 Replies
05-09-2012 02:54 PM
I just drew a polyline on my defpoints layer, but now the polyline is not selectable. I have had this happen before with a different file and couldn't fix it then either.
All the settings/layer states look fine, but as soon as I add something to the defpoints layer it's untouchable.
Not an urgent question, but definately something I need to figure out since it keeps happening to me!
Thanks!
a
AutoCAD Civil 3D 2010
Active Contributor
dsigman
Message 2 of 12 (3,203 Views)
Re: Defpoints layer not selectable
05-09-2012 03:18 PM in reply to: yasin2ray
Try turning on layer 0. Should fix the problem.
BrianHailey
Message 3 of 12 (3,186 Views)
05-09-2012 05:45 PM in reply to: yasin2ray
A better solution would be to not use defpoints. Why are you using defpoints? Most likely because it won't plot. In the last several releases you can set any layer to not plot and so the use of defpoints is no longer needed. Why do I recommend you don't use defpoints? Well, you already found one. The other reason, if you were to shelve this drawing for 6 months and then come back to it. All that stuff that's on the defpoints layer, why is it there? You probably will forget but, if you have a layer set to not plot called, "notes to drafters", then you know what that stuff is.
Just my thoughts on the subject.
Active Contributor
dsigman
Message 4 of 12 (3,171 Views)
05-10-2012 09:25 AM in reply to: BrianHailey
That's how i've been handling it for years. I have a no-plot layer for my survey calc's and one for surveyor's notes. Occasionally I'll use defpoints to make a hatch boundary. I suppose I could add a no-plot layer for hatching but it's easy enough to use defpoints. I never touch layer 0 so it's not a problem.
Valued Mentor
owenmull
Message 5 of 12 (3,157 Views)
05-10-2012 02:37 PM in reply to: dsigman
And the Cad Guru said unto his minions, "Thou shalt not use DEFPOINTS!"
-Owen
Windows 7 x 64 bit
NVidia Quadro K3000M Dual Monitor
32.0 GB RAM
Intel Core i7-3820QM @ 2.70 GHz
Civil 3D 2013 SP 2
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
yasin2ray
Message 6 of 12 (3,142 Views)
05-11-2012 11:11 AM in reply to: BrianHailey
Cad people... always cracking me up. Thanks for a little humor with this one while I'm not having a total breakdown.
I tried turning on the 0 layer, but Defpoints still misbehaved a bit (invisible or visible but untouchable).
I'll go with the suggestion to make my own "no plot" layer and turn on the 'no plot' setting.
Thanks ya'll!
Member
Message 7 of 12 (2,663 Views)
01-05-2013 06:31 AM in reply to: yasin2ray
I just had this problem. Turning on Layer 0 in the model didn't help, BUT if you open the Layer Properties Manager, right click on Layer 0 and select VP Thaw Layer in All Viewports, this does it. Seems if Layer 0 is frozen in your layouts, it locks the Defpoint layer in the model.  Go figure.
I use the Defpoints layer all the time and it's not usually a problem.  I use it to create grids to lay out elevations, create insertion points for blocks, etc. :smileyhappy:
wfberry
Message 8 of 12 (2,650 Views)
01-06-2013 07:46 AM in reply to: BrianHailey
Hey Brian:
As you know, I am older and probably more set in my ways than you.  Just wap me with a wet noodle the next time you see me.  I have been using defpoints since day one with no problems as far as I know.
I can't help it.
:smileyhappy:
Bill
BrianHailey
Message 9 of 12 (2,647 Views)
01-06-2013 08:25 AM in reply to: wfberry
"With great age comes great stubborness"
I'm just waiting for the next replacement for C3D comes out and then I'll be all like, "Well in Civil 3D you did it this way. How come I can't do it that way in this new software?"
Distinguished Contributor
sadekcivil
Message 10 of 12 (2,638 Views)
01-06-2013 12:42 PM in reply to: yasin2ray
you can edit the layer name and change it from defpoints to defpointse as an example and put select your object and do what you like to do and eventually rename the depoints layer to the default name to use it again
Thank you.
Sadek
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
