Hi Guys
Is there a way to define object data to a polygon or a poly line in C3d? I imported a shape file and saw that in the properties dialog box the object data of the polygons is displayed. I would like to define create new polygons and define certain atrributes to it before exporting it as a shape file. This would would eliminate the need to use a GIS program to define the attributes of the polygons.
Im using PCSWMM and would like to define certain atributes to polygons and polylines in C3D before i import it in to PCSWMM.
Thanks in advance
Yes. The data you see when importing a .shp file is called Object Data and can be added to AutoCAD objects via Map 3D (which Civil 3D is built upon). If you don't get a decent answer here on how to do this I would recommend asking in the Map 3D group as they will probably have more users that are familiar with those tools.
After creating an object data table you can use ADEATTACHDATA command to attach the OD table to the objects
To create a Table
See image in here
To attach a table to object
see this image
