Every time I go to use the water drop tool on a surface I have to change from the default layer 0 to my 'water drop' layer. I'm sure there must be a way to change it but I couldn't seem to find it in the surface styles...
Yes, there is.
Go to Settings Tab-->Surface-->Commands-->Right Click 'CreateSurfaceWaterdrop'-->Edit Command Settings-->Expand 'Water Drop Path'
Here you can set the default layer from '0' to whatever you want.
Fantastic. Thanks, I managed to change it by toggling the "Save Command Changes to Settings" to 'Yes', then creating a water drop under my specified layer then going back and toggling it to 'No'... but this way is MUCH more straightforward
Thanks again
